Hi,
The instructions contained with the BT Mini Connector Kit specifically state that is for connecting a BT Smart Hub to a TV set-top box.
Can it be successfully used to connect a HH5 to a PC please ?
@albertjwrote:
I would think so. I believe they're just standard powerline adapters. Trying it won't break them, so give it a go!
Many thanks for the reply.
If only trying them was that easy, I would have done so. However, it means a quite significant re-arrangement of my offce and I do not want to do so only to find they dont' work, then have to re-pack them for return.
Has anyone actually used them to successfully connect to a PC from a non Smart Hub please ?
@pompey1898wrote:
@albertjwrote:
I would think so. I believe they're just standard powerline adapters. Trying it won't break them, so give it a go!Many thanks for the reply.
Conversely, has anyone had problems connecting them to a PC from a non Smart Hub please ?
