Message 1 of 3
BT Mini Connectors - WiFi Hotspot?
Hi,
Does the receiving/remote/second BT Mini Connector create a local WiFi Hotspot or can it only be used via a wired ethernet connection?
Thanks,
Kevin
2 REPLIES 2
Message 2 of 3
Re: BT Mini Connectors - WiFi Hotspot?
Just Ethernet, you need a mini wifi hotspot 600 to provide wifi and Ethernet
Message 3 of 3
I thought as much, £20 down the drain... Will phone up and see if can do a swap.
Thanks for your help!
