Message 1 of 3
BT Mini Hub Passwords - Network and Admin
I am just posting this here because the advice given on this forum is not up to date. The network password and SSID name for the mini hub is on the card that comes with the BT Minihub. If you lose this it is also on the sticker that is attached to the back cover of the BT Mini Hub.
Also note that this is where you will find the Admin password. It is NOT on the card. The Admin password allows you to get into the interface and amend the SSID, password etc as you would with any router hub.
The interface is minicab.home or you can access it at 192.168.1.1
I hope this is clear!
2 REPLIES 2
Message 2 of 3
Re: BT Mini Hub Passwords - Network and Admin
The admin password for the BT EE mini hub is NOT on the Hub, or the box. Is it perhaps inside the lid?
Message 3 of 3
Ah ha! The details are on the inside of the lid...
