Fady
Message 11 of 20
Re: BT Mobile - no coverage indoors😡
Yes - I've been aware that wifi calling is being tested. But has been unter test for a while with no indication as to how 'soon' soon actually is...
Fady
Message 12 of 20
Hi Dean007
I seem to be posting simultaneously to you 🙂 Thanks for the tip about the trials. I'll research this.
Dean007
Recognised Expert
Message 13 of 20
Has it been under test for a while? I think realistically it maybe be the end of the year before wifi calling would be rolled out- but this is just my guess!
 You will see what trials are running and you are often compensated for being on a trial. Smiley Wink
Keith_Beddoe
Message 14 of 20
@Fady wrote:
Hi Dean007
@Fady Please see   Sign up to join a BT Product Trial
csrothwec
Message 15 of 20
I am now back with my original mobile provider and (fingers crossed!!!) everything going well. Strong, consistent signal, have not had to restore my iPhone once to get a signal again. Also great to know I could contact the technical help of the provider easily if I wanted/need to (unlike trying to speak to someone from BT, which is about the equivalent of trying to get a direct line to Hilary Clinton or whoever!)
Dean007
Recognised Expert
Message 16 of 20
Hi csrothwec
glad your move back was painless. Hope the signal stays strong! I'm not sure I would want a direct line to Hilary lol but we get ya!
Flooda
Message 17 of 20
Thanks All for your posts. Still no joy even changing to 2G. I was on O2 and coverage was fine.
With regards BT trials, is it simply googling BT trials or wait for them to email??
Thanks once again for your efforts
Dean007
Recognised Expert
Message 18 of 20
Register then set up your equipment profile. They then message you and invite to take part.
Keith_Beddoe
Message 19 of 20
@Flooda see Sign up to join a BT Product Trial
Oleir
Message 20 of 20
many thanks for your posts! I'll try to join BT product trial as well...but I'm not sure I'll wait till the end of it..i'd sooner decide upon buying a hiboost repeater, stella looks overpriced 🙂 ee repeater doesn't fit me as I need a solution for other networks
