Newbie
Message 1 of 4
BT Net Protect
Am installing Net Protect on a Windows 7 64 bit machine with expired McCaffee Software still present. On running the Net Protect installer I get a finishing message to restart windows.  Windows will not restart - I can only go to Safe Mode and
then  find a Restore point.  I have now tried 3 times to complete the installation with the same result.
What to do ??
3 REPLIES 3
Message 2 of 4
Re: BT Net Protect
Uninstall the expired product first.
Distinguished Guru
Distinguished Guru
Message 3 of 4
Re: BT Net Protect
After uninstalling, it might be as well to run the McAfee removal tool before reinstalling so that you start with a clean sheet. You can download the tool here: http://service.mcafee.com/FAQDocument.aspx?id=TS101331
Newbie
Message 4 of 4
Re: BT Net Protect
Keith Beddoe  and Potty Person
Thanks very much for your replies -perfectly good advice . Unfortunately the failure in windows occurs immediately after removal of the McAffee code by any method  (whichever comes first) . The removal tool itself indeed  says it failed. This means this is a McAffee problem and therefore I will vanish from this forum - thanks again
