@Patty-L wrote:Well I have BLASTOFF all downloaded and working OK icons etc all there, I don't think it was the download misfired it was
my fault (as usual) but I got there in the end. PP hope you haven't got cramp from hiding under the table!!
Thank you both for your help much appreciated.
Pat
That's good to hear Patty
Did you also run the BTNP removal tool to rid your PC of any snippets left behind, even after you think it's all gone - http://bt.custhelp.com/app/answers/detail/a_id/38369/c/346 (section 4 onwards)
Also, if you like to use the McAfee site advisor with MSE, then that works well too;)
DS said.....
Yes I did that Thank You
Just got rid of the Wrigley's to say that an occasional scan with the free version of Malwarebytes Anti-Malware is recommended alongside MSE.
Just so are more esteemed members are aware (in case of query's) net protect is now working with windows 8
