Message 1 of 15
BT NetProtectPlus with McAfee: Google Hijacker
I have an option 2 contract which comes with BT NetProtect.
For the past week I have been afflicted by a Google Hijacker.
My google queries get diverted to sites I didn't ask for, such as Yell.com
Ihavenet.com is one of the sites involved, but there are others.
I have run full McAfee scan several times, but it doesn't seem to recognise the existence of this virus.
Anyone got any ideas of what to do.?
I use XP
pe58
14 REPLIES 14
Distinguished Guru
Message 2 of 15
Re: BT NetProtectPlus with McAfee: Google Hijacker
Hi pe58 and welcome
Install a program called Malwarebytes.
Note that it now appears to be a trial version with lots of extras:(, but will help. Run it and let it find the junk that BTNP can't remove.
Then if you don't like the extras it now comes with, simply uninstall it after you've finished with it.
-+-No longer a forum member-+-
Message 3 of 15
Thanks DS, will try it in a couple of days when I have a bit more time pe58
Message 4 of 15
Thanks    Catcher will have a look later pe58
Message 5 of 15
DS: I have tried Malwarebytes.  It picked up 3 infections I wasn't aware of [Pub.Adbundle], but didn't detect my hijacker.  Thanks anyway pe58
Message 6 of 15
Try via file hippo Super anti spyware as well.
AQ.
"Welcome to Royston Vasey - You'll never leave."
Message 7 of 15
Sorry to hijack your thread pe58 but my post with the link has been removed with no explanation - bit unprofessional.
Distinguished Guru
Message 8 of 15
@Catcher, I noticed that too:o
(for any future readers, it was just another browser. I've used it myself on and off for years, but guess the link broke a forum rule).
@pe58, not saying you should try any of this but this (the hijacker) has been removed back in 2010, so it's probably worth a read.
http://www.geekstogo.com/forum/topic/278245-google-hijacker-removal-solved/
and a forum thread on the removal
http://www.geekstogo.com/forum/topic/267407-how-to-fix-google-redirects/
should these links go, simply search for Google Hijacker - it's all there;)
Community Manager
Community Manager
Message 9 of 15
Hi Catcher,
I removed that link.  I dropped you a PM just after this to explain my actions, sorry for any confusion caused Smiley Happy
Cheers
Sean
Message 10 of 15
And I have replied
