Addy
Message 1 of 2
BT Netprotect Plus and Full Scan.
Hi,
I have installed the latest version of BTNNP (V3.8.1.1) and when trying the full scan there doesn't seem to be a pause option. When I stop the full screen and then restart it, say after shutting down the laptop, it seems to start at 0 again and as far as I can tell it starts at the beginning.
If a full scan is stopped does it start the next time where it left off? If not is it possible to pause it so it remembers for the next time.
thanks
1 REPLY 1
Liam_
Recognised Expert
Message 2 of 2
Re: BT Netprotect Plus and Full Scan.
When performing a scan for virus etc you have to let the scan complete. Especially if you are turning off the PC/Laptop. Some scanners will allow a pause, provided you don't shut down before its finished you can let it continue after the pause. If you stop the scan then next time it's run it will start at the beginning.
