Message 1 of 16
BT Openreach Huawei HG612 3B VDSL/FTTC Fibre Modem
I have the above coming tomorrow to replace my HH5 (Infinity 2 approx 80/20) then I can use another Wifi Router. Anyway wanted to know should i just plug and play or do i need to update the HG612 with any firmware before use? any info appreciated.
15 REPLIES 15
Message 2 of 16
Re: BT Openreach Huawei HG612 3B VDSL/FTTC Fibre Modem
the modem should be plug and play  if you use third party router then you need to set username to bthomehub@btbroadband.com and any password will do  also needs to be set at PPPoE not A
Message 3 of 16
@imjolly will i be able to see stats on this device? if so, how is this done? Thanks.
Message 4 of 16
You will need to unlock it to be able to see the stats.  See here for instructions how to do that.
Message 5 of 16
@licquorice with it being a used item, is there an easy way to find out if the device is locked or unlocked when it arrives? Cheers.
Message 6 of 16
See if you can connect to it on LAN port 2 192.168.1.1 (admin/admin) If you bought it on ebay, I would have thought it would have been sold described as either locked or unlocked.
Message 7 of 16
@licquorice would it make any difference locked/unlocked? i.e. I can still change the firmware etc?
Message 8 of 16
If its locked you can't do anything with it (other than use it Smiley Happy ), changing the firmware using the method I linked to is the unlocking process.
Expert
Message 9 of 16
You also need to update the firmware if you require g.inp to version B030SP08.
Message 10 of 16
Which is all part of the instructions I linked to.
