dsouzacolin
Newbie
Message 1 of 4
BT Openreach Telephone Landline Fault
Today I had my BT Openreach installed. My telephone landline no longer works. When I plugged my analogue phone into the Tel 1 or Tel 2 socket I receive an intermittent beeping tone. I plugged my Sky +HD into the Tel 1 and the phone line connection is recognised. Do I need to call an engineer or is there a simple solution ?
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: BT Openreach Telephone Landline Fault
Should you not be plugging into the normal phone socket?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
dsouzacolin
Newbie
Message 3 of 4
When I plug my phone into the normal phone socket I'm getting no tone.
dsouzacolin
Newbie
Message 4 of 4
I phoned BT 0330 1234 151 from my mobile this morning. The Call Centre phoned me back and had diagnosed the fault from the exchange. I was told that it would take 3 working days for an engineer to look at the fault. This evening my landline was working again. Smiley Very Happy
