Geoff765
Message 1 of 6
BT Openreach to HH5
Hi,
I am on Fibre to the Premise fibre optic link and I have a BT Openreach modem in the hall. The Home Hub 5 is connected to Port 1. I would like to move the HH5 to another room. Could I use a BT Flex extender in the hall to link from the BT Openreach Port 1 via mains cable to an extender in the other room with the HH5?
In the past, I would just have plugged the splitter into an adjacent telephone outlet in the other room, but with the BT Openreach modem the telephone and broadband signals split at the BT Openreach modem. Hence, the problem of getting the broadband signal to the other room.
Any comments?
5 REPLIES 5
licquorice
Message 2 of 6
Re: BT Openreach to HH5
You could, but you might find that the speed is not that great, the speeds quoted are often optimistic. Normally this wouldn't be the governing factor, but with high speed FTTP it could be. The ideal option would be to run a CAT6 ethernet cable.
Geoff765
Message 3 of 6
That would be a better solution. Unfortunately, I think my wife might object! As for speed, with the HH5 in the hall, the wireless link drops speeds to 3-4Mbps. The sppeds through the Flex extender are quoted as upto 500Mbps; is htis optimistic?
I note that the BT Openreach modem port 1 cable goes into the HH5 WAN socket. Does this factor into the consideration?
licquorice
Message 4 of 6
@Geoff765 wrote:
That would be a better solution. Unfortunately, I think my wife might object! As for speed, with the HH5 in the hall, the wireless link drops speeds to 3-4Mbps. The sppeds through the Flex extender are quoted as upto 500Mbps; is htis optimistic? Yes, but it will depend on the quality of your mains wiring and any induced noise. It will certainly be better than wireless.
I note that the BT Openreach modem port 1 cable goes into the HH5 WAN socket. Does this factor into the consideration? Not really, it's still Ethernet.
Geoff765
Message 5 of 6
Oops. Correction. Its not a BT Openreach modem, it is a BT Openrach Optical network box. It does not connect to the Broadband DSL port on the HH%. It connects to the Broadband WAN.
licquorice
Message 6 of 6
Yes, guessed that. Smiley Happy It's still Ethernet.
