Message 1 of 3
BT Parental Controls Unavailable - blocked from a website
I need urgent help!
On Tuesday (12th Feb) I noticed I was being blocked from a website which said my BT Parental Controls had blocked it because of Light Filters.  I tried the "allow access" link, but it said I didn't have authority to change this and to contact the Account Holder - I AM THE ACCOUNT HOLDER??!?
I logged onto BT.com but my BT Parental Controls say it's unavailable.  I called up to ask what had happened and was told to reset my Hub, which I've and after 24hours no difference.  I called again yesterday (14th Feb) and they still can't figure out what has happened. As suggested I again re-set my hub, but to no avail.  This error has lasted since the 12th Feb and it seems no one at your end knows what the problem is?!
I urgently need to get onto this particular website and it's blocking me!
I see this has happened to others - can you please sort this out.  It's obviously a glitch at your end, and it's costing me money as I can't work.
2 REPLIES 2
Message 2 of 3
Re: BT Parental Controls Unavailable - blocked from a website
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Message 3 of 3
Hi @Simbo4Elvis,
I am sorry to hear that your Parental Controls service doesn't appear to be active. We'll need to get it fixed for you. I've sent you a private message detailing how you can reach us.
DanielS
