DavidM
Moderator
Moderator
Message 21 of 24
Re: BT Parental Controls Unavailable
Hi @Sphere,
Thanks for getting back. I'm sorry this isn't sorted yet. I've passed the details back to the parental control team and will be in touch as soon as I have any updates for you.
Cheers
David
DavidM
Moderator
Moderator
Message 22 of 24
Hi @Sphere,
I'm sorry for the delay in getting back to you. I called this afternoon, sorry I missed you. I've had confirmation that the parental controls issue has been resolved so can you check that and let me know?
Cheers
David
Sphere
Message 23 of 24
I was informed you called I apologise for not being present. I can confirm that the issue has been resolved. I would like to thank you for looking into this issue for me, had you not I'm not sure the access to parental controls would have been fixed. Once again thank you Dave 👍
StuartH
Moderator
Moderator
Message 24 of 24
Hi @Sphere
Thanks for posting to let us know.
I'll pass on the kind words to @DavidM
Stuart
