Chimaoge
Message 1 of 9
BT Parental Controls Unavailable
Hi Moderator
I have an ongoing problem with BT Parental Controls now showing as "UNAVAILABLE"( see screen shot attached )
Can you please assist?
Many thanks in advance.
8 REPLIES 8
PaddyB
Moderator
Moderator
Message 2 of 9
Re: BT Parental Controls Unavailable
Hi @Chimaoge,
I'm sorry you're having problems with your Parental Controls. Did you manage to get this fixed?
If not, I'll be able to get this sorted for you. You can send me in your details using the "Contact the Mods" link found in my profile.
PaddyB
Chimaoge
Message 3 of 9
Hi PaddyB
Thanks for getting in touch.
I can confirm that this issue is still unresolved.
I tried but haven't been able to locate the "Contact the Mods" link on your profile page.
Can you send me a hyperlink please.
Best regards.
JohnC2
Moderator
Moderator
Message 4 of 9
Hi @Chimaoge Sorry about that. I have enabled the link for you on my profile.
PS you may not see the link if you are viewing the site in mobile view.
Cheers
John
Chimaoge
Message 5 of 9
Got it JohnC2,
Many thanks
Chimaoge
Message 6 of 9
Hi JohnC2,
I have uploaded my details.
JohnC2
Moderator
Moderator
Message 7 of 9
Hi @Chimaoge I can see the faults team have been in touch to say the problem should be fixed now. Have you had a chance to check this yet? Post back and let me know.
Cheers
John
Chimaoge
Message 8 of 9
Hi JohnC2,
I can confirm the offline team have successfully reinstated Parental controls on my account.
Many thanks for your help with resolving the problem and for following up.
Hellsbelles6787
Message 9 of 9
Hi, I have the same problem. My parental controls used to work but I logged into my bt hub to allow my kodi box (which I no longer use) so I want try to enable the controls again and it just says unavailable. How do I get the option to turn then back on. I have tried looking at your profile and can't see contact the mod or anything and I am viewing the full site. Thanks.
