legitimise_sailing
Distinguished Expert
Message 11 of 40
Re: BT Reveals UK FTTC Self Installation and Vectoring Broadband Trials
1000m line length is significant because ADSL2+ is faster at that point.
To say thanks for a helpful answer, please click the white star
ryant704
Guru
Message 12 of 40
Wrong, it's just above.
It's about 26.5Mbps FTTC, I would know my line is basically 1000m. 🙂
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
legitimise_sailing
Message 13 of 40
That's the difference between theory and practice 😉
So what would you class as a long line for FTTC?
ryant704
Guru
Message 14 of 40
1200+ when it hits top ADSL speeds.
curiousfellow
Message 15 of 40
So, can anyone sum up for the laymen amongst us exactly what this means for those on FTTC!?
ryant704
Guru
Message 16 of 40
Vectoring is a piece of hardware that helps prevent crosstalk, it also has it's own software which is rumoured to make a line run better with the DLM and able to record more faults remotely (rumoured).
microspud
Message 17 of 40
Surely with the self install they will still need a BT engineer to connect the user from the PCP to the DSLAM cabinet???
john46
Message 18 of 40
yes it will but that can be done on the activation day
imjolly
Message 19 of 40
a link with bit more information on vectoring  http://www.pcworld.com/article/2035767/vsdl2-on-steroids-takes-off-as-broadband-over-copper-declines...
microspud
Message 20 of 40
In relation to the comment about ADSL2+ and VDSL speed at distances > 1 km...
A VDSL connection is essentially made up of many carriers of signal (DMT modulation) 4khz wide, think of them as channels on a TV.
imagine the more channels you can recieve the higher the speed in total you will get.
The lower frequency channels (used by ADSL2+ and VDSL) can travel further down the line with attenuating (degrading) due to noise etc.
This is also a general rule for radiowaves, the lower the frequency the easier the signal can travel through walls and other obsticales without issues.
So ADSL2+ and VDSL share the benifits of the lower frequency channels, and therefore > 1km the effect should be roughly the same.
However VDSL attempts to use 17Mhz worth of these channels accross the spectrum (hence 17a), as you go up the frequency spectrum the high frequency signals will either pass the grade or not (thats what the Target SNR -signal to noise ratio is for), and if so will contribute to your final connection speed.
All very clever, but its important to note that VDSL is basically very simular to ADSL2+ technically.
Hope I didnt send you off to sleep.
Source: my head but for backup... http://computer.howstuffworks.com/vdsl4.htm
