Message 11 of 14
Re: BT Smart Hub 2 device connections
from your stats your connection time is only 3hrs and your current connection speed is only 23mb compared to the attainable of about 58mb.  your noise margin is very high at 26.6db whereas normal is about 6db.  this suggests drops in connection or many manual resets trying to improve connection speed
Message 12 of 14
@imjolly Thanks! Here you go:
Message 13 of 14
as you can see from checker results estimated connection speed range is 50/35mb and currently you are below the handback of 30mb
Message 14 of 14
@imjolly
Many thanks - you are much more informative than BT/Openreach have been! To be fair they keep responding/trying solutions but do not seem to be making progress! An Openreach engineer turned up this morning (his second visit) and said because the line speed was 55Mbps he couldn't do anything - either the Hub was faulty or there was a wiring/device problem. When BT in Cardiff contact me they tell me my line speed is poor (!) and that they/Openreach need to fix it!!
BT are due to make another follow-up call tomorrow (!) - do you have any thoughts on what I should say to them (preferably polite ones!) ? So far, they have already sent me a replacement hub (it was only a Smart Hub, not a Smart Hub 2, and made no difference) and have even terminated two extension wires (which to be fair we weren't using) to try to boost line speed but again no improvement.
Your comment in your other post re line noise is interesting because they did detect that about a week or two ago and told me that they had cleaned it up!
