DarrenJ1
Message 11 of 14
Re: BT Smart Hub 6 Green Light
Yeah did a factory reset the other day and smart setup disabled straight away
Hazy1980
Message 12 of 14
I've had 5 Smart Hubs, all failed. Back on a home hub 5.
My first one worked fine until the November firmware update, since then all have failed the same way, a few days after updating to the latest firmware from the pre loaded May 2016 version the hub becomes unresponsive eventually leading to a flashing green (sometimes with purple) and won't even factory reset.
The Smart Hub is a dud
DarrenJ1
Message 13 of 14
I've admitted defeat on it and ordered a non BT replacement from Scan.
im having the same problem the hub it's self stops responding can't even access 192.168.1.254 until it reboots so can't just be a dropout on the phone line. It was fine until the firmware update of a few weeks ago.
DanielS
Moderator
Moderator
Message 14 of 14
Hi @DarrenJ1,
If you still need help with it please get in touch with us by clicking on my user name and then on contact the mods. We'll then get back in touch with you over the next few working days.
DanielS
