Message 1 of 4
BT Smart Hub Devices
Hi,
Can I ask why in the below screenshot the number of devices on the Smart Hub (18), is higher than the sum of the 8 Ethernet devices, plus the 6 wireless devices?
I can see my extra wireless devices when I click on the Smart Hub 18, but they are not appearing in the wireless section count.
Hope that makes sense!
Thank you
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub Devices
Its basically because the SH2 network map is flaky to say the least.
Message 3 of 4
Try using the filters - connected devices - disconnected devices.
Click on each category, 5Ghz,  2.4Ghz. You can view the devices listing.
The sums usually add up, but if someone is using you BT Wi-fi as a connection, then you may have to think.
Message 4 of 4
All the 18 devices listed are known to me as I keep a log of MAC addresses and name devices.  The four extra are all wireless devices which are plugged in and 'green'
