Cooltrain
Message 1 of 9
BT Smart Hub Disable BT Wifi
Hey,
So under my smart hub manager under Home > Status there is a bottom area called BT Wi-fi Status Image.
How can I disable this? If I follow the link "Click here to go to the BT Wi-fi page" The login information for my BT account do not work.
Any ideas?
Thanks.
8 REPLIES 8
john46
Message 2 of 9
Re: BT Smart Hub Disable BT Wifi
DavidM
Moderator
Moderator
Message 3 of 9
Hi @Cooltrain,
Welcome and thanks for posting. @john46 link should show you how to sort this but if you get stuck let us know.
Cheers
David
Cooltrain
Message 4 of 9
Thanks for the link but I don't think I have a @btinternet.com email to login with, I don't know what type of account I need to login with ?
Liam_
Recognised Expert
Message 5 of 9
Use the contact email address you used when ordering the service.
Cooltrain
Message 6 of 9
Does that mean my BT ID email or the address that I ordered my BT with ? Becuse there are both the same and it doesn't work in this case.
Liam_
Recognised Expert
Message 7 of 9
That's odd.  I used the email address setup when ordering on the phone and never had any problems.  Same when moved back to BT, used the email used for online order then once activated logged in and created new email addresses and changed the log in mail address.  I guess there are no typos?
Cooltrain
Message 8 of 9
No typos, using the same email thats the BT ID, and the same password for it ( Which works when signing in to view my Bill, ect). Which is why I was confused that it was a diffrent email.
licquorice
Message 9 of 9
In theory, your BTID email address should work, in practice the whole BTID/password/MyBT/BTwifi  system is a complete dog's breakfast and only seems to work for some and not others!!
