john46
Message 351 of 763
Re: BT Smart Hub (Home Hub 6) Bug Reporting + Improvements
just turn off smart wireless it is not needed
fred2103
Message 352 of 763
Already done that months ago and followed best advice on here on set up.
athlonoc
Message 353 of 763
HI all,
Thought I would keep thread going. Convinced HH6 is at fault. I've tried two now and problems similar to those mentioned in this thread.
RANDOM dropouts ( anytime of day - more than once etc. )
Today I decided to see if it was my connection or wireless router
Tablets / sky Q / phones etc just couldn't connect so I connected laptop via RJ45 cable and could access the internet and smart hub interface.
This to me would infer that the wireless element of the hub is at fault and not the moden element.
Am I right in my assumption and therefore should I now go back to BT and request another router.
JUST A THOUGHT
Is there any way to get hold of the various firmwares and flash the Hub to see which firmware works best for me. It appears to auto update whether you want the firmware upgrade or not. Currently on 16/11/16
I've two engineer visits in last 2 months to deal with poor speed on Infinity Fibre and all is good now after new Openreach Master Socket and cable replaced.
smf22
Recognised Expert
Message 354 of 763
- Yes you proved the problem was wireless related.
- Little point in requesting another hub as the problems are caused by firmware or configuration. The hardware is the same commodity hardware used in many other third party products and so not likely to be an issue.
- No there's no way to get any version of the firmware.
cinek
Message 355 of 763
wifi drop out is not resolved with the latest firmware, it "fixed" the issue for about a week.......... wtf bt!!!
fred2103
Message 356 of 763
Less than that for me...even 21EC was better so 1 step forward 2 back with 2236.
As they are on Hub No. 6 you would have thought the basic reliable functionality
would be easy peasy by now. Who tests this firmware as each iteration is
no better or worse than the last?
fred2103
Message 357 of 763
Getting the odd occasion when the Smart Hub is broadcasting with -50db reasonably good
 signal (wifi analyser) but the connection has dropped and 'no network is detected'.
A computer reboot doesn't appear to fix it. Tried both the built in Wifi adapter (Broadcom)
and a plug in Netgear USB wifi adapter (A6100) and both had the same issue
so unlikely to be an issue with slightly incompatible 'Wifi chips' assuming that could be
a potential issue.
After a lot of faffing about it comes back a few minutes later and all is well
for a short time (lots of 'connecting' but not succeeding).
Can anyone explain how you can have a full router signal but no working connection
or no network detected?
The Wifi analyser shows other users with lower signal strengths as well as mine.
Getting near the point of going the 3rd party router route if next firmware release
doesn't improve things significantly.
TP-Link VR2600 Version 2 gets mainly good reviews but still a small but significant
proportion of users who have issues with it worringly similar to the Smart Hub.
V1 had a few issues until firmware updates mostly sorted it and V2 has a
slightly different updated Broadcom chipset. Will wait until further reviews appear to
confirm it's still OK or a new firmware is released (no new one's currently).
Can anyone recommend it as could be opening another can of worms if luck
runs out?
licquorice
Message 358 of 763
@fred2103 wrote:
Can anyone explain how you can have a full router signal but no connection
Because they are operating at different layers of the ISO model. You can have wireless connectivity without IP connectivity.
oldforger
Message 359 of 763
I truly despair of the HH6 I have purchased from BT; it is completely unreliable, it has completely messed up my home network,  drops connections to devices at random, messed up a long established VPN connection, confused my home plug set-up which was previously rock solid and has made me a very unhappy BT customer.
I wish I had never bought the **bleep** thing to be honest. Understandable on early iterations of a device but by the 6th generation this shouldn't happen. Not fit for purpose in my view.
I know it is not just me experiencing this frustration as evidenced by the tide of dissatisfaction expressed on these boards under various threads.
Thank you for allowing this small rant (which I fully realise solves nothing and is ultimately pointless) and goodnight.
fred2103
Message 360 of 763
Not sure if weather is affecting things but Smart Hub (2236 firmware) has been absolute
rubbish today with no networks found on 2.4 and 5 Ghz bands for long periods
and when it did come up frequent disconnections with the blue light glowing solidly
throughout (maybe mocking me!!!). Resets didn't help.
Please BT DO SOMETHING ABOUT THIS PILE OF ............
