Message 101 of 211
Re: BT Smart Hub - Wi-Fi Issues
If only they would let us do a manual upgrade.
Just noticed the hidden manual firmware upgrade page is still there even on the HH6 !
http://192.168.1.254/firmware_upgrade
Expert
Message 102 of 211
If my experience is anything to go by, you're much better off sticking with the firmware you've got! See my comments on other threads.
p
Message 103 of 211
Had three of these now. All work fine for three days then nothing. No internet connection. Got refund, now back on HH5 with no problems. Seems like they rushed these out with very little testing. When they work very good. They just don't work for long.
Message 104 of 211
Put the HH5 back again. Think I might leave it a few months before trying the HH6 again hoping it will download the latest firmware.
Message 105 of 211
 Hi,
Found this thread very helpful so I thought I'd share my experience with the amazing new Smart Hub from BT.
I bought a Smart Hub 6 from BT a few months ago and had several problems with it so returned it for refund. My exchange has just been upgraded to allow us to have fast fibre BB so I have just upgraded to infinty 2 and was supplied with a Smart Hub 6. All was fine for first few days, then 5 Ghz signal failed to connect with any device. Powered off and on and problem resolved. Yesterday the 5 Ghz signal vanished from the connected devices and despite power down and factory resets and various channel configurations, the 5 Ghz signal remained lost. The Hub manager wireless page showed it to be on but the home page summary had the 5 Ghz signal status as off.
Called BT Support today and having followed all the tech advice to no avail, I am now being sent a replacement Hub6 to arrive tomorrow. Hoping it will be third time lucky, not holding my breath though...
Message 106 of 211
I contacted BT on 31st October regarding my HH6 because the WiFi was hanging up a few times per day on the 2.4 GHz channel. I was surprised to be advised to set my WiFi channels to 11 (for 2.4 GHz) and 44 (for 5 GHz), do a Save, then power cycle the hub. Much to my surprise this seems to have made it behave great again. I can only think that certain WiFi channels are interfering with the hub's internal electronics. Please could someone else who is having WiFi issues try this, as it may help them too, and will maybe show that it's not just coincidence that my HH6 is now behaving again.
Message 107 of 211
To add to the above, I am also opted out of BT FON at present, as I don't want that starting up and causing trouble if it is on a bad channel.
Message 108 of 211
I think rebooting the Hub anyway tends to fix the problem temporarilly but doubt this is a permanent fix.
Good luck and keep us informed. I do not think wifi interference is the issue but more the way the Hub assigns ip addresses.
Message 109 of 211
Well, I was rebooting hub a few times per day. Now with channels 11 and 44 as suggested by BT support person it has been up for nearly two days. Fingers crossed, and hope someone else can try it!
Message 110 of 211
I received the same advice from BT Support regarding Ch 11 and ch 48 on the HH6 with my original hub trying to resolve the 5Ghz band issue. That didn't help and I now have a replacement HH6 which has behaved itself for three days now and I've also set the wifi bands to Ch 11 and Ch 48 respectively. I'll see how it goes now.
Oops, I didn't spot the channel advice to you was 11 and 44 and not the same as given to me.
