Craggle
Message 1 of 9
BT Smart Hub Worse Than Home Hub 5 For WiFi
So I have a Fire TV in the upstairs bedroom of a small house and wifi signal on the Fire TV has always been 'Fair' using a Home Hub 5. So the other day I see an advert of Mr Deadpool hanging from a helicopter and he was raving about how good his signal was as he was taken into the stratosphere. So I thought to myself, self, I need some of that Smart Hub, so I ordered one and it arrived today.
I swapped over the Home Hub 5 for the Smart Hub and changed the obligatory security settings. Wired connections are a lot faster but now my Fire TV wifi strength is now showing 'marginal' and even no connection. I've tried changing channels 1,6,11, I seperated the 2.4ghz and 5ghz and tried connecting to both of them but still worse than Home Hub 5.
So what now? Has Deadpool betrayed me?
8 REPLIES 8
imjolly
Message 2 of 9
Re: BT Smart Hub Worse Than Home Hub 5 For WiFi
have you tried changing the mode from 1 to either 2 or 3
Craggle
Message 3 of 9
Thanks for your reply. I forget to mention I did change the modes to 2 and 3 with no difference. I wasn't going to change them as it said something like, it would make the distance shorter but I did try it.
Slightly stunned that this brand new product that's meant to have a stronger wifi range is worse than my old Home Hub 5.
imjolly
Message 4 of 9
Yet I have been using hh6 for a few weeks and certainly find wireless stronger than hh5
Craggle
Message 5 of 9
Can I ask what channel and mode do you have it set to?
imjolly
Message 6 of 9
Currently fixed at channel 6 and 40 and mode 1
Craggle
Message 7 of 9
Thanks, tried that already. If anybody has other ideas? it looks like I will be going back to Home Hub 5 as Smart Hub has less powerful range regards wifi for me.
Dpleech
Message 8 of 9
I have the same problem. My Fire TV is directly above the router on the next floor. 2.4ghz shows no signal, and 5ghz shows 1 bar. I also have a ps4 next to it which shows nearly full signal strength for both 2.4ghz and 5ghz bands. This makes me think the Fire TV is at fault, as I have never been able to get a strong signal with it from my hh5.
Craggle
Message 9 of 9
Dpleech it may well be the Fire TV but I would have thought if I was getting a 'fair' signal from the Home Hub 5 considering the Smart Hub is meant to have a stronger and better range I would expect the same or better signal not worse like it is now.
I even thought about buying the newer Fire TV with 4K  if it had updated the wifi strength so I asked Amazon if this was the case and they confirmed the 4K Fire TV has exactly the same wifi internals as the original Fire TV.
