Message 1 of 2
BT Smart Hub with a Netgear D7000v2 as a slave via Cat 6 cable
I have a BT smart hub in the house and connected via cat 6 cable a Nighthawk D7000v2 in my new annex some 50 meters away. The WiFi keeps dropping in and out in both locations.
when I told BT they supplied a wholehome dual band AC2600 unit which when connected via the Cat6 cable gives OK WiFi but no opportunity to hardwire smart TV's etc. So I would really want the Nighthawk to work. I am not that technical.
1 REPLY 1
Message 2 of 2
Re: BT Smart Hub with a Netgear D7000v2 as a slave via Cat 6 cable
Give the Nighthawk an address of 192.168.1.10, disable DHCP and connect a LAN port on the hub to a LAN port on the Nighthawk.
