announcedworm
Message 1 of 6
BT Smart Phone
Hi,
I have just bought a new BT Smart Phone. I am a bit disappointed with it as it does not come with the Google Play app for Android, just with Opera Mini, which is good for social networking sites like Facebook but is useless for any other Android app. You cannot even get the Met Office app or the BBC weather app with Opera.
I am really looking to know if there is a way of downloading the more popular apps. To my knowledge you cannot download the Google Play app as it has to come pre-instilled on the device.
If anyone can help I would be most grateful.
Thanks.
5 REPLIES 5
toekneem
Distinguished Guru
Message 2 of 6
Re: BT Smart Phone
According to the blurb, all games, apps etc have to be downloaded from the opera mobile apps store
toekneem
(EASBF)
announcedworm
Message 3 of 6
Re: BT Smart Phone
Hi,
That is the problem; Opera mobile apps store is really, really bad.
Ectophile
Distinguished Guru
Message 4 of 6
Re: BT Smart Phone
Have you tried downloading the Google Play App from the google web site? https://play.google.com/store/search?q=google%20play
announcedworm
Message 5 of 6
Re: BT Smart Phone
Have tried to do as was suggested but it would appear, as I previously thought, that unless the device has Google Play pre-instilled it is not possible to download apps.
imjolly
Message 6 of 6
Re: BT Smart Phone
can you not download the app  .apk file to your pc and then load on to your smartphone - side load- and see if that will work
