Message 11 of 15
Re: BT SmartHub 2 Smart Setup
Unbelievably, BT Technical Support didn't mention the MyBT App! They were asking me to login via the browser. I will re-install the SmartHub 2 and try this route (Firmware requirements noted).
Message 12 of 15
you can still turn 2.4 or 5ghz  off or on in hub using browser and save the changes  you don't need the app for that but you do need app for parental controls
Message 13 of 15
In that case it would seem like a browser issue, perhaps try a different web browser?
Its sounds like a lot of extra effort for nothing, if your HH6 works fine, and you are not interested in the BT Complete Wifi Solution, which the smart hub 2 was intended for.
Message 14 of 15
hi , did the new hub work , I have tried switching off 5Khz without success ,
Ken
Message 15 of 15
sorry , just seen your other post , Should I ask them for an oldhub
Ken
