Message 1 of 4
BT SmartHub frozen on green startup light - need replacement
Hi,
My BT SmartHub has frozen on the green startup light, wont respond to factory-reset pin press.
Am using old HH5 for now however would like my Smart Hub replaced due to being faulty.
3 REPLIES 3
Message 2 of 4
Re: BT SmartHub frozen on green startup light - need replacement
This is a BT residential customer to customer forum. Your post does not go to BT. You will need to contact BT and report a fault.
Message 3 of 4
I posted on here as I know BT Support occasionally monitor these forums!
Message 4 of 4
But they won't intervene with a simple problem until normal channels have been exhausted.
