Hi all, just to add to the list of these threads heh.
I was previously on 8mb ADSL, using a Homehub 4, and moved to BT Infinity 2 with a SmartHub6 on the 26th October.
However I'm still experiencing routine connection dropouts, this isn't constant, but seems multiple times a day at least, and when it happens, the disconnections are grouped together (like within minutes of eachother). This isn't something I had with my old connection and Homehub. That usually used to last until the fortnightly reboot.
As to now I don't think my speed has been affected too much, (though as you can see I'm getting a bit less than the stated 80?, whereas before I used to get 7+ out of the max 8mb). I'm connected directly to the router by ethernet, and the router is plugged into the Master Socket (Single socket faceplate, with a filter, which is the same filter as what I was previously using).
Could someone give my stats a look over please and see if this is normal? (I'm seeing a lot of other posts with similar issues with these SmartHubs..):
BT Speed Test:
Ookla Speed Test: (Interestingly after a bout of connection drops, this seems to default to a different location than where I am. Such as it thinks the nearest server is in Manchester, or Scotland! When my nearest is0 Sheffield)
Router Logs are in Post 2.
Let me know if you need any other info, cheers.
Solved! Go to Solution.
Router Info:
Product name:
BT Hub 6A
+084319+NQ63103785
SG4B10002236
30-Oct-2016
1.0
1.32.0
0 Days, 7 Hours 25 Minutes 45 Seconds
20.00 kbps / 79.99 kbps
20000 / 89466
8.7 / 8.8
8.1
0 / 81
0/38
G_993_2_ANNEX_B
Fast Path
431 MB Uploaded / 2239 MB Downloaded
bthomehub@btbroadband.com
Not active
BTHub6-2NQ3-2
Smart (Channel 1)
BTHub6-2NQ3-5
Smart (Channel 36)
WPA2 (Recommended)
Off
Mode 1
On
88:A6:C6:04:D9:25
7.33.1
(If there's a more readable way of posting this stuff then let me know..)
Router WAN Log 1:
15:13:17, 16 Nov.
:WAN: SENSING AUTO VDSL
15:13:07, 16 Nov.
ptm0.101:VLAN VLAN_DATA connected
15:13:07, 16 Nov.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
15:13:07, 16 Nov.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
15:13:07, 16 Nov.
dsl:VDSL link Up: Down Rate=89466Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
15:12:46, 16 Nov.
:VLAN VLAN_DATA disconnected
15:12:40, 16 Nov.
dsl:VDSL Link Down: duration was 6393 seconds
13:26:52, 16 Nov.
13:26:07, 16 Nov.
13:26:07, 16 Nov.
13:26:07, 16 Nov.
13:26:07, 16 Nov.
dsl:VDSL link Up: Down Rate=89530Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
13:25:50, 16 Nov.
13:25:40, 16 Nov.
dsl:VDSL Link Down: duration was 122 seconds
13:23:50, 16 Nov.
13:23:38, 16 Nov.
13:23:38, 16 Nov.
13:23:38, 16 Nov.
13:23:38, 16 Nov.
dsl:VDSL link Up: Down Rate=89498Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
13:23:17, 16 Nov.
13:23:11, 16 Nov.
dsl:VDSL Link Down: duration was 753 seconds
13:10:48, 16 Nov.
13:10:38, 16 Nov.
13:10:38, 16 Nov.
13:10:38, 16 Nov.
13:10:38, 16 Nov.
13:10:19, 16 Nov.
13:10:11, 16 Nov.
dsl:VDSL Link Down: duration was 133 seconds
13:08:09, 16 Nov.
13:07:59, 16 Nov.
13:07:59, 16 Nov.
13:07:59, 16 Nov.
13:07:59, 16 Nov.
dsl:VDSL link Up: Down Rate=89434Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
13:07:38, 16 Nov.
13:07:32, 16 Nov.
dsl:VDSL Link Down: duration was 61036 seconds
20:10:58, 15 Nov.
20:10:16, 15 Nov.
20:10:16, 15 Nov.
20:10:16, 15 Nov.
20:10:16, 15 Nov.
dsl:VDSL link Up: Down Rate=89594Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
20:09:57, 15 Nov.
20:09:49, 15 Nov.
dsl:VDSL Link Down: duration was 15176 seconds
15:57:03, 15 Nov.
15:56:53, 15 Nov.
15:56:53, 15 Nov.
15:56:53, 15 Nov.
15:56:53, 15 Nov.
15:56:31, 15 Nov.
15:56:26, 15 Nov.
dsl:VDSL Link Down: duration was 793 seconds
15:43:22, 15 Nov.
15:43:13, 15 Nov.
15:43:13, 15 Nov.
15:43:13, 15 Nov.
15:43:13, 15 Nov.
dsl:VDSL link Up: Down Rate=89339Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
15:42:51, 15 Nov.
15:42:46, 15 Nov.
dsl:VDSL Link Down: duration was 517 seconds
15:34:19, 15 Nov.
15:34:09, 15 Nov.
15:34:09, 15 Nov.
15:34:09, 15 Nov.
15:34:09, 15 Nov.
dsl:VDSL link Up: Down Rate=89403Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
15:33:48, 15 Nov.
15:33:42, 15 Nov.
dsl:VDSL Link Down: duration was 23774 seconds
08:57:38, 15 Nov.
08:57:29, 15 Nov.
08:57:29, 15 Nov.
08:57:29, 15 Nov.
08:57:28, 15 Nov.
08:57:07, 15 Nov.
08:57:01, 15 Nov.
dsl:VDSL Link Down: duration was 4907 seconds
07:35:51, 15 Nov.
07:35:14, 15 Nov.
07:35:14, 15 Nov.
07:35:14, 15 Nov.
07:35:14, 15 Nov.
dsl:VDSL link Up: Down Rate=89371Kbps, Up Rate=24073Kbps, SNR Margin Down=9.20dB, SNR Margin Up=6.00dB
07:34:57, 15 Nov.
07:34:45, 15 Nov.
dsl:VDSL Link Down: duration was 1639 seconds
07:07:37, 15 Nov.
07:07:27, 15 Nov.
07:07:27, 15 Nov.
07:07:27, 15 Nov.
07:07:27, 15 Nov.
07:07:06, 15 Nov.
07:07:00, 15 Nov.
dsl:VDSL Link Down: duration was 68081 seconds
Router WAN Log 2:
12:12:31, 14 Nov.
12:12:19, 14 Nov.
12:12:19, 14 Nov.
12:12:19, 14 Nov.
12:12:19, 14 Nov.
dsl:VDSL link Up: Down Rate=89243Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
12:12:00, 14 Nov.
12:11:52, 14 Nov.
dsl:VDSL Link Down: duration was 3717 seconds
11:10:05, 14 Nov.
11:09:55, 14 Nov.
11:09:55, 14 Nov.
11:09:55, 14 Nov.
11:09:55, 14 Nov.
11:09:34, 14 Nov.
11:09:28, 14 Nov.
dsl:VDSL Link Down: duration was 33313 seconds
00:01:23, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
dsl:VDSL link Up: Down Rate=89403Kbps, Up Rate=24022Kbps, SNR Margin Down=9.10dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
:WAN: ethernet as LAN
01:52:33, 14 Nov.
dsl:VDSL Link Down: duration was 1171244 seconds
01:52:33, 14 Nov.
03:51:38, 03 Nov.
12:32:13, 31 Oct.
12:32:03, 31 Oct.
12:32:03, 31 Oct.
12:32:03, 31 Oct.
12:32:03, 31 Oct.
dsl:VDSL link Up: Down Rate=85456Kbps, Up Rate=13463Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
12:31:44, 31 Oct.
12:31:36, 31 Oct.
dsl:VDSL Link Down: duration was 90 seconds
12:30:16, 31 Oct.
12:30:06, 31 Oct.
12:30:06, 31 Oct.
12:30:06, 31 Oct.
12:30:06, 31 Oct.
dsl:VDSL link Up: Down Rate=90421Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
12:29:52, 31 Oct.
12:29:39, 31 Oct.
dsl:VDSL Link Down: duration was 68 seconds
12:28:41, 31 Oct.
12:28:31, 31 Oct.
12:28:31, 31 Oct.
12:28:31, 31 Oct.
12:28:31, 31 Oct.
dsl:VDSL link Up: Down Rate=90516Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
12:28:11, 31 Oct.
12:28:04, 31 Oct.
dsl:VDSL Link Down: duration was 99 seconds
12:26:54, 31 Oct.
12:26:25, 31 Oct.
12:26:25, 31 Oct.
12:26:25, 31 Oct.
12:26:25, 31 Oct.
dsl:VDSL link Up: Down Rate=90485Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
12:26:03, 31 Oct.
12:25:58, 31 Oct.
dsl:VDSL Link Down: duration was 17979 seconds
07:26:32, 31 Oct.
07:26:19, 31 Oct.
07:26:18, 31 Oct.
07:26:18, 31 Oct.
07:26:18, 31 Oct.
dsl:VDSL link Up: Down Rate=90453Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
07:25:59, 31 Oct.
07:25:51, 31 Oct.
dsl:VDSL Link Down: duration was 616 seconds
07:15:45, 31 Oct.
07:15:35, 31 Oct.
07:15:35, 31 Oct.
07:15:35, 31 Oct.
07:15:35, 31 Oct.
dsl:VDSL link Up: Down Rate=90548Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
07:15:18, 31 Oct.
07:15:08, 31 Oct.
dsl:VDSL Link Down: duration was 10258 seconds
04:24:22, 31 Oct.
04:24:10, 31 Oct.
04:24:10, 31 Oct.
04:24:10, 31 Oct.
04:24:10, 31 Oct.
dsl:VDSL link Up: Down Rate=90198Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
04:23:49, 31 Oct.
04:23:43, 31 Oct.
dsl:VDSL Link Down: duration was 6567 seconds
02:35:00, 31 Oct.
02:34:16, 31 Oct.
02:34:16, 31 Oct.
02:34:16, 31 Oct.
02:34:16, 31 Oct.
02:33:54, 31 Oct.
02:33:49, 31 Oct.
dsl:VDSL Link Down: duration was 23548 seconds
00:01:36, 01 Jan.
00:01:22, 01 Jan.
00:01:22, 01 Jan.
00:01:22, 01 Jan.
00:01:22, 01 Jan.
dsl:VDSL link Up: Down Rate=90421Kbps, Up Rate=25108Kbps, SNR Margin Down=9.40dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
19:58:35, 30 Oct.
VDSL Link Down: duration was 726 seconds
19:58:35, 30 Oct.
00:01:21, 01 Jan.
00:01:11, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
VDSL link Up: Down Rate=90604Kbps, Up Rate=25990Kbps, SNR Margin Down=9.60dB, SNR Margin Up=8.80dB
00:00:23, 01 Jan.
03:08:49, 30 Oct.
03:08:39, 30 Oct.
03:08:38, 30 Oct.
03:08:38, 30 Oct.
03:08:38, 30 Oct.
VDSL link Up: Down Rate=89784Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
03:08:20, 30 Oct.
03:08:11, 30 Oct.
VDSL Link Down: duration was 131432 seconds
Aaaand it does it again, and now my upload is almost halved 😐
Shall I just dump this **bleep**ty router for a better one?
15:07:37, 28 Nov.
15:07:07, 28 Nov.
15:07:07, 28 Nov.
15:07:07, 28 Nov.
15:07:07, 28 Nov.
dsl:VDSL link Up: Down Rate=84024Kbps, Up Rate=11130Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
15:06:50, 28 Nov.
15:06:40, 28 Nov.
dsl:VDSL Link Down: duration was 543 seconds
14:57:47, 28 Nov.
14:57:37, 28 Nov.
14:57:37, 28 Nov.
14:57:37, 28 Nov.
14:57:37, 28 Nov.
dsl:VDSL link Up: Down Rate=89116Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
14:57:15, 28 Nov.
14:57:10, 28 Nov.
dsl:VDSL Link Down: duration was 157 seconds
14:54:46, 28 Nov.
14:54:34, 28 Nov.
14:54:34, 28 Nov.
14:54:34, 28 Nov.
14:54:34, 28 Nov.
dsl:VDSL link Up: Down Rate=89212Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
14:54:13, 28 Nov.
14:54:07, 28 Nov.
dsl:VDSL Link Down: duration was 4567 seconds
13:38:14, 28 Nov.
13:38:00, 28 Nov.
13:38:00, 28 Nov.
13:38:00, 28 Nov.
13:38:00, 28 Nov.
dsl:VDSL link Up: Down Rate=87270Kbps, Up Rate=19637Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
13:37:35, 28 Nov.
13:37:33, 28 Nov.
dsl:VDSL Link Down: duration was 83 seconds
13:36:10, 28 Nov.
13:36:10, 28 Nov.
13:36:10, 28 Nov.
13:36:10, 28 Nov.
13:35:51, 28 Nov.
13:35:42, 28 Nov.
dsl:VDSL Link Down: duration was 667 seconds
13:24:46, 28 Nov.
13:24:36, 28 Nov.
13:24:36, 28 Nov.
13:24:36, 28 Nov.
13:24:36, 28 Nov.
dsl:VDSL link Up: Down Rate=89148Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
13:24:17, 28 Nov.
13:24:09, 28 Nov.
dsl:VDSL Link Down: duration was 30297 seconds
00:01:35, 01 Jan.
00:01:09, 01 Jan.
00:01:09, 01 Jan.
00:01:09, 01 Jan.
00:01:09, 01 Jan.
dsl:VDSL link Up: Down Rate=89021Kbps, Up Rate=24296Kbps, SNR Margin Down=9.30dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
04:57:31, 28 Nov.
dsl:VDSL Link Down: duration was 227788 seconds
04:57:31, 28 Nov.
Your own 3rd party router/modem combo will always be better than anything any ISP supplies.
Interesting, I'll look into it then cheers.
I'm aware that a lot of others are having problems with the SmartHub6 (despite the "pro" reviews lol..)
However I thought that it would be fixed soon! Not like I had a choice anyway as I didn't have the equipment to run my old Hub 4 with it. Didn't have the chain-disconnect though like with this one, don't know why it drops so many **bleep** times in one go.
It would appear there are lots of problems with the HH6.
Bought a TP-Link VR2600. Hopefully this will be more stable.
Got my upload back to 18-20 at least with the reconnect, woo!
Do come back and let us know how you're getting on with the TP-Link.
