Message 61 of 63
Re: BT SmartHub6 Connection Routinely Dropping
@NeilO
Well, I'm happy to say I've had not a single connection drop (besides that SmartHub restart, but that's a router reboot so eh) since the engineer visit. The TP-Link has been fine also. Connection completely stable, nice and fast, happy customer.
If only all BT's support was this good (no India..), they'd get a much better rep! Many thanks all.
Far as I'm concerned, case closed. Cheers! 🙂
Moderator
Moderator
Message 62 of 63
@Bob36 That's great thanks for keeping the thread updated. I hope you don't mind I've marked the thread solved as I'm happy that you're happy it's sorted.  If you need any help in the future post back Smiley Very Happy
Message 63 of 63
Certainly am, the lift & shift obv sorted it.
Thanks a lot mate.
