Deezzaa
Message 1 of 7
BT Speed Test says performance is poor
I've had Infinity since November and the increase in speed has been so-so. I ran the speed tool and got the following:
 When you see a BT Diagnostic say "Could be improved" and "Poor", you naturally think something is wrong.
So I had an online "chat" with BT helpdesk which lasted over 2.5 hours of my life (which I'll never get back) during which they tried a lot of things before concluding "It's within limits".
Well the diagnostic tool did not say "it's within limits" it said "Could be improved" and "Poor".
Who is right? The official diagnostic tool or the helpcentre guys? Or both? It is within limits but tough luck, that's what you're getting...
What do I do now, or do just I put up with expensive wretched performance? Remember I'm paying exactly the same as those who are enjoying far faster speeds with BT Infinity.
6 REPLIES 6
gg30340
Message 2 of 7
Re: BT Speed Test says performance is poor
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
Deezzaa
Message 3 of 7
Here are the screen shots as requested:
john46
Message 4 of 7
can you please post the further diagnostics part of the speed test also the help desk page from the troubleshooting section of the hub manager
Deezzaa
Message 5 of 7
I hope this is what you want:
gg30340
Message 6 of 7
It looks as though you have a fault on your line and DLM (Dynamic Line Management) has kicked in and lowered your speeds to try and maintain a connection. You noise margin is to high and the nice round numbers in you data rate would tend to confirm this.
You need to contact BT and ask them to send out an engineeer to investigate what the problem is.
Deezzaa
Message 7 of 7
That's really helpful. Thanks for that.
Now why couldn't the on-line chat function (the "preferred" method) have been so efficient and saved me over 2 hours of frustration.
Now the problem is to try to find out how to contact them to send out an engineer...
