Icarus5000
Message 1 of 1
BT Speedtester Change?
Has anyone tried to run a speedtester on www.speedtester.bt.com today?
I started a line test as normal and walked away from my PC for a few minutes as I am sure you are all aware they take forever but when I came back to my PC I found the message below on my PC. Does anyone know if this refers to the Quality of Service for the BT Vision Service, which I do have?
Anyway if anyone gets this mesage and you don't have problems with your quality of service you need to click EXIT and not Continue otherwise you just get a pop up telling you to click a box?!
