Recognised Expert
Message 1 of 3
BT Speedtester [no system errors].?
The BT Speedtester is giving a scrolling message stating that it has no system problems.
But it then gives me a result of 26Mbps download.
Two tests done a few minutes later to speedtest.net give me the results below, and real life file downloads agree with them.
So how can there be no problems with the BT tester.?
http://speedtest.net/result/1862148887.png
http://speedtest.net/result/1862147921.png
2 REPLIES 2
Message 2 of 3
Re: BT Speedtester [no system errors].?
Hi
    This is the result I just got from BT speed tester and then speedtest.net.
Its not too far apart, maybe the system is just a few ups and downs.
Recognised Expert
Message 3 of 3
Yeah you could be right Nige,and it might be that the tester server is located badly for me,and other test sites might be more stable for me.
But if that is true then as a main ISP test server it can only be used to check profiles,not thoughput,as it could give bad readings depending on our locations.?
