MiloM3
Message 1 of 29
BT Speedtester
Is anyone else having problems with BT Speedtester? www.speedtester.bt.com
It takes ages to load on my desktop PC which is connected via ethernet to BT Option 3, but when I load it on another computer connected to a different ISP it loads fine.
All settings are correct on both machines.
28 REPLIES 28
jjgraphics
Recognised Expert
Message 2 of 29
Re: BT Speedtester
Yes, its not working here at all.
The BT Speedtester rarely works reliably for very long. Try using another, such as:
http://www.mybroadbandspeed.co.uk/speedtest
Icarus5000
Message 3 of 29
Re: BT Speedtester
The www.speedtester.bt.com is run, managed and maintained by BT so therefore will only work on average once out of every one hundred try’s.
You are better off using a third party speed tester;
www.speedtest.net
www.speedtest.bbmax.co.uk
Or the BBC one is really good.
http://www.bbc.co.uk/iplayer/diagnostics
ippylad
Message 4 of 29
Re: BT Speedtester
The BT Speedtester is a joke, it doesnt work in peak times (the time when most people have issues) and in my case it will not accept any of my details to run a test. BT have given me my Service ID and still no joy! Yet they insist you use this to show you have a fault!!
Message 5 of 29
Re: BT Speedtester
The speedtester had issues yesterday during some update work but is working ok now  Other isp's also use the BT  speedtester as well it is the universal  excepted test  as it is the only one that shows IP Profiles
jjgraphics
Recognised Expert
Message 6 of 29
Re: BT Speedtester
Still not working here.
Message 7 of 29
Re: BT Speedtester
not working for me either - can't even get on to the page
Moderator
Moderator
Message 8 of 29
Re: BT Speedtester
Hi guys,
Thanks for posting. I'll check with wholesale and get back to you once we get any updates.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
NilSatisOptimum
Recognised Expert
Message 9 of 29
Re: BT Speedtester
Its flying now, however its kept working .  Only checking due to dropped profile.
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
jjgraphics
Recognised Expert
Message 10 of 29
Re: BT Speedtester
Still not working here (0118).
Browser said: "Contacting speedtester.bt.com" for almost five minutes before first page loaded VERY slowly. Then clicking on the the "ADSL and Fibre to the Cabinet (FTTC) Speed Test " button produced no response.
