Message 1 of 11
BT Sport App on iphone 6 problem
Have been using the app on the phone without a problem via my very good wifi connection
Lately I cannot get any live video just the VC011 error
I can get the video on my computer with no problems
BT support has been poor
How do I check that the app on my phone is using my home wi-fi and NOT looking for a 3G or 4G connection?
10 REPLIES 10
Moderator
Moderator
Message 2 of 11
Re: BT Sport App on iphone 6 problem
Hi @bobneish54,
You can check the settings in the BT Sport App, it will show if you've enabled mobile streaming. When you notice the issue, can you check your internet connection by trying to watch a video on YouTube?
If that works okay, log out of the BT Sport App, restart it, then log back in again.
Let me know how you get on?
PaddyB
Message 3 of 11
Tried that - no change in error
When I was out tried a completely different and solid wifi connection and same occurred
Message 4 of 11
PaddyB
Need some more advice on how to solve this
Distinguished Guru
Message 5 of 11
Hi @bobneish54,
Does the connection work when you disable the WiFi on your mobile? That will tell you if it's using your mobile data connection. Another way to check is to go to the Settings menu in the app. Make sure that 'Enable Mobile Streaming' is set to 'off'.
Have you cleared the apps data and cache or uninstalled it and downloaded a new copy to rule that out as the cause?
Thank you
DanielS
Message 6 of 11
Daniel
Tried all that and error remains the same
Deleted and redownloaded app - still the same
How do i clear cache etc??
Regards
Bob neish
Moderator
Moderator
Message 7 of 11
Hi Bobneish54,
What IOS version is your Phone Running? And can you also confirm what version of the BT App you are using?
You can find out the version of the BT App by going into settings and then "About" and it should confirm the version number.
PaddyB
Message 8 of 11
iOS: 9.3.1
BT: 2.14.0
Moderator
Moderator
Message 9 of 11
Hi @bobneish54
Thanks for posting back and confirming both versions.
Can you try the advice on this page
Failing that we may have to get your details for this to be investigated as you've tried quite a few things now that haven't got you sorted out.
Post back and let me know how you get on with this.
Cheers,
Robbie
Message 10 of 11
Robbiemac
You are the man
Once deleted my Bob profile all started working
Not sure why that is because I've had it installed for along time
Which alternative free Bon should I use to continue watching by sport and also helping to stay secure
Many thanks
Bob
