Message 1 of 11
BT Sport App stopped working on my Samsung TV (VC034 code)
Whenever I try to play any video on the BT Sport App, it loads for a while and then says:
"Sorry - there's a problem playing the video."
with code VC034
That's on a Samsung smart TV so on Tizen.
The online BT help doesn't have anything about this particular error code.
I've tried uninstalling and installing the BT Sport App, didn't help.
10 REPLIES 10
Message 2 of 11
Re: BT Sport App stopped working on my Samsung TV (VC034 code)
Unfortunately it's not a very helpful error code - it just tells us that your TV didn't know how to play the format of the video you selected. All Samsung 2015+ TVs support all our video formats, so there's no valid reason for it to fail.
The only 2 suggestions we can make are:
1. Reboot the TV (hold the power button on the remote until the TV reboots and shows the Samsung logo)
If that didn't fix it then:
2. Factory reset the TV
If neither of those work then unfortunately you'll need to call Samsung for support.
Message 3 of 11
Thank you for the quick reply. I've tried the reboot and now when playing a video I've received another error code: VC019
Message 4 of 11
Live video does work, it's only catch ups that don't
Message 5 of 11
OK, now your TV is saying it's having a connection issue to our video clip provider. Are you able to watch the clips in a web browser from the same internet connection? https://www.bt.com/sport/watch/video/catch-up/2021/june/motogp-highlights-grand-prix-of-catalunya
Message 6 of 11
Yep, it works for me in a browser.
Message 7 of 11
That's me out of ideas then, other than the factory reset. Or maybe confirm your software is up to date? Can't think why your TV would fail to connect if your PC can from the same internet connection.
Message 8 of 11
I've tried factory reset and I'm still getting VC019 and/or VC034 error codes. Seems kinda random.
I've found that some live feeds did work. However, currently the live MotoGP feed doesn't work at all nor any of the MotoGP catch ups.
It might be that Samsung TVs are sensitive to something you're doing with the video stream.
Message 9 of 11
I can see your multiple attempts in the last 30 minutes, and the errors have all been either a failed connection, or your TV saying the video format isn't supported. I'd still be inclined to suggest something weird with the internet connection from your TV, but I don't know what.
Message 10 of 11
I've restarted my router and it appears to be working now 😮
