cal1304
Message 1 of 18
BT Sport Channel is not there
Ok new Problem!  My Viewing card came today which has been activated!  but when i scan for new channels it doesn't find BT Sport!  its simply not there at all!!!  i have all the other channels just no BT Sport!!
I have a BT Vision+ box with BT Broadband (not fibre)
17 REPLIES 17
StewM
Guru
Message 2 of 18
Re: BT Sport Channel is not there
Where are you looking? You should have channel 57 - 59?
cal1304
Message 3 of 18
when i try go on those channels it say unavailable
pottyperson
Distinguished Guru
Distinguished Guru
Message 4 of 18
As Stew says. You should get the channels with or without the card, but if it's without or if the card is faulty you'll just see an "Encrypted Channel" message. Not so. I've caught up now!
StewM
Guru
Message 5 of 18
Actually PP, through the Vision Box I can only see Channel 57. On my TV I can see 57 - 59. The Vision Box must block 58 & 59?
So perhaps there is different software for BT Sports over Freeview?
cal1304
Message 6 of 18
there is nothing there 😞  I have been told by BT Staff that I can get the channels and i have also been told that i cant get the channels!
2 hours on the phone and i am still none the wiser
StewM
Guru
Message 7 of 18
Do you not see any of 57, 58 or 59?
Can you see ITV 3?
cal1304
Message 8 of 18
nope i don't have any of those channels
StewM
Guru
Message 9 of 18
OK, lets back track a little.
Before the card arrived, could you see channel 57?
cal1304
Message 10 of 18
no the channel has never been there
