stuartrogerson
Distinguished Guru
Message 261 of 263
Re: BT Sport Europe Presentation
Pressing the red button gives a full screen picture.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
StewM
Guru
Message 262 of 263
Yes Stuart on the Sky platform but only in SD , even though you may subscribe to HD.
On  BT TV you can go to BT Extra 6. But that has no EPG so in effect you can only record live programmes or programmes which are replays with the Lbar.
I am still of the opinion that this is a wasted channel.
Stew
neila4
Message 263 of 263
BBC 1 with logos at the top or BT Sports 2 with logos at the bottom for the FA Cup Final? Which did you watch?
