wysesr2
Message 11 of 23
Re: BT Sport HD Recordings not watchable - Error IPC6041
I've got the same error code and looking at the link for Maintenance Reset it takes you through a full Factory Reset which loses all the recording and settings, is there a way to avoid this?
gavinlambourne
BT TV Expert
Message 12 of 23
Hi @wysesr2. Right now, I don't believe there is. We are aware of this issue and working to find the root cause.
wysesr2
Message 13 of 23
Thanks for the update, as it is only 1 recording I cant watch I'll hold off doing a full factory reset at the moment then.....
gavinlambourne
BT TV Expert
Message 14 of 23
@wysesr2 - For the recording that is currently giving the IPC6041 error at playback, are you able to make a new recording for a different program on the same channel and successfully playback?
adamashby
Message 15 of 23
If you follow the instructions for Factory Reset using the buttons on the box, there is an option for Factory reset do not delete files. Use that option...
wysesr2
Message 16 of 23
Thanks will look at that option as well....
gavinlambourne
BT TV Expert
Message 17 of 23
Hi@wysesr2. Did you try the reset option with keep recordings, did it resolve the issue for you?
wysesr2
Message 18 of 23
I did a bit more investigating over the last few days and was able to record successfully on some HD and SD channels however I couldnt record anything on all the channels I subscribe to (AMC, BT Sport 1, 2 and 3 in both SD and HD). The only exception was BT Sport 1 which did record successfully.
I haven't done a full box reset yet as I have been trying other things, sounds as though there is a problem with the way my subscription is set up but happy to hear what others think.
wysesr2
Message 19 of 23
Decided to do a Factory Reset, not given the option to keep recording but decided there was nothing I couldnt lose.
Factory reset done, now have NO subscribed channels so cant see any of the BT Sport or AMC channels (in either SD or HD) so cant even watch them now!!
gavinlambourne
BT TV Expert
Message 20 of 23
Hi @wysesr2. When you say you have no IP channels, do you mean they are not even appearing in the programme guide?
