Message 1 of 2
BT Sport - Premiership Rugby Union - channels keep changing
After an other match not being recorded, I am getting pretty frustrated by the haphazard way that Premiership Rugby Union coverage is being haphazardly moved around the channels on BT Sport - BT Sport 1,2,3 and BT Extra 1,2,3.... - no consistency - I can't guarantee which channels I can record on series link - it seems that RU is treated as very poor relation to soccer and, possibly, UFC!
As a minimum they should be able to guarantee one channel consistently e.g. BT Sport 3 so at least one channel can go onto series link, and then other matches go on BT Sport Extra channels
Is anyone else having a problem with this?
1 REPLY 1
Message 2 of 2
Re: BT Sport - Premiership Rugby Union - channels keep changing
I have had this with other sports coverage too. All I can suggest is that you do a final check on the day of each event to make sure the timers are still set up OK.
