Newbie
Message 1 of 4
BT Sport Terrible Audio Quality
Hi, I've just got the infinity package and thought I'd watch a bit of footy to give BT sport a try out.... the audio quality is shocking. Tinny, muffled...is this normal? I can't believe they can get away with serving this rubbish up to customers. Any feedback would be appreciated before I put a complaint in. All the sport channels are the same, I've not tried any other streaming stuff yet.
Cheers, Phil.
3 REPLIES 3
Newbie
Message 2 of 4
Re: BT Sport Terrible Audio Quality
Just tried some other channels and all had terrible audio. Swapped the hdmi connection from port 3 to 4 and all audio now ok. Swapped the lead back and still ok. I'd checked all leads were in ok...strange. I'll update this if it comes back as I wonder whether it's a box or cable issue.
Recognised Expert
Message 3 of 4
Could have been an HDMI handshaking glitch?
Distinguished Guru
Distinguished Guru
Message 4 of 4
Is it because you need to use the HDMI ARC port?
