Message 21 of 38
Re: BT Sport VC086 post Catalina and Safari upgrade on MAC
Problem has returned today though, and with a vengeance! Was ok yesterday.
Message 22 of 38
Sorry. That is not true. BT Sport will not run on Safari, on my Mac. And I am running High Sierra!
Message 23 of 38
Yes, resorted to using Chrome now.  Sad to say BT take too long each time to correct the issue.  The Techies must be a little slow on the uptake!
Message 24 of 38
I had the same problem so I went to safari preferences clicked on websites and allowed pop ups on Bt Sport and I had no further problems getting BT sport on safari.
Message 25 of 38
Just tried that. Didn't work for me.
Message 26 of 38
I see the VC086 error still exists you can watch any video but if you try to watch anything that's live VC086 error always appears meanwhile I will continue watching BT Sport on another browser.
Message 27 of 38
I have found a solution that has worked for me, after spending ages trying loads of things I deselected enable java script in safari preferences security tab which made all the web sites unusable, I then reselected enable java script and live bt sport was working fine.I have tried a number of times bt sport worked every time.
Message 28 of 38
Just tried this three times. NO JOY!
Message 29 of 38
The latest upgrade to Catalina, 10.15.3,  'seems' to have fixed this problem. 😀
Message 30 of 38
Thanks. That works for me.
