leibniz
Message 1 of 4
BT Sport - Wireless
Can somone give me a good technical explanation why I cannot connect my BT Vision box to the home hub wirelessly for the sports channels?
I can stream directly to my PC or Tablet, but I need a 35 foot cat5 cable just to watch a football game on my TV?
3 REPLIES 3
StewM
Guru
Message 2 of 4
Re: BT Sport - Wireless
Because the Vision Box does not have any wireless equipment built in
leibniz
Message 3 of 4
I've added a netgear wireless adaptor which while running at 100Mb, is apparantly insufficient to stream a football game, while at the same time being sufficient to stream top gear.
Go figure.
cljxr27
Message 4 of 4
You could also use the Power Line adaptors that route the LAN over the Mains sockets in your house. This works ok for PC's but not sure for TV, theres a certain way you have to connect them without using extension leads.
