Message 1 of 6
BT Sport and ESPN HD
Could somebody confirm that as a bttv customer with the HD extra pack, should i be getting the sports channels in HD automatically or do i need to suscribe to these seperately. At the moment i only get these channels in SD as a screen comes up telling me to suscribe to the HD versions.
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: BT Sport and ESPN HD
Things might have changed since I moved to Sky but it was included. It may perhaps now be chargeable - perhaps you should ask this in the BTTV forum.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Moderator
Moderator
Message 3 of 6
Hi peter1uk,
The BT Sport HD channels are not included with the HD extra pack.  To get BT Sport in HD you need to subscribe for these check out this link BT Sport HD for more info.
Neil
Distinguished Guru
Message 4 of 6
That web page states the following,
HD Extra
A selection of TV channels in high definition for stunning picture quality and glorious detail. If you add HD Extra with BT Sport you'll also get BT Sport in HD at no extra cost.
Also the current residential tariff guide (page 42) says,
**  If you take the BT Sport HD pack there will be no charge for BT Sport HD if you have HD Extra.
So it seems very clear that it should be free for HD Extra + BT Sport pack subscribers.
Distinguished Guru
Message 5 of 6
That's what I thought
Helpful Post?
Distinguished Guru
Distinguished Guru
Message 6 of 6
As I nuderstand it
The BT Sport HD channels are not included with the HD extra pack. - however currently if you take the HD extra pack there is no charge for the BT Sport HD pack. But  you still need to order the BT sport HD .
There are other promotions that provide free BT Sport HD for differing promotional periods.
