Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
I have BT Broadband and a BT Vision+ box (I have had both of these for many years). I registered for BT Sport in May and this shows as being set up in My BT. The BT Sport channels appear in my channel listing on the Vision+ box but when I select I get a message at the bottom of the screen that says "Please ensure that the Viewing Card is in the Viewing Card Slot" - It is. Then a second message appears saying "The gold chip faces up with the arrow pointing into the card slot" - It is. If I remove the card and then re-insert it I get a red message at the top of the screen saying"Viewing Card recognised" - but I still get the above messages followed by a third message "To activate card go to channel 941" - I have done this and input the numbers on the back of the card. I now get a message that says that this is for "sports card activation" - I haven't received a new card so I input the numbers from the back of my card. Guess what? I now get a message "Unfortunately your order can't be processed at the moment...put the card back in the slot....try again in another hour...." I have done this on many occassions over the last 4 days. Still no joy.
I have even tried to order a £10 card online (not as I feel that I ought to ) but I am not able to complete the order either. I am stuck, can anyone help?
When i first got into BT Sport I had to leave the channel on for 2 hours while thevi viewing card was activated
Thanks for your reply, have you got a new card or have you been able to watch BT Sport using the existing card (if you had one)?
I'm using the old card which I already had
Thanks for that, I will try leaving it on the BT Sport channel for a few hours, and see if I get the same result.
What colour is your box?
It's the black one.
