Message 1 of 3
BT Sport on Sky not HD
I used to have BT Sport on Sky, switched to BT TV and have now reverted to Sky Q again having it activated by BT as a broadband subscriber.
Only problem is whereas previously it was HD on Sky Q now it isn't and the BT Sport HD channels require a separate subscription. I was told there is no cooling off period, is there an option available to upgrade my BT Sport back to HD again through BT rather than more expensively via Sky?
2 REPLIES 2
Message 2 of 3
Re: BT Sport on Sky not HD
You can add the HD addon for £6.50 per month, as an addon it can be removed when not required with 30 days notice, it has no bearing on your minimum term either and won't extend or renew anything.
Message 3 of 3
Thanks -Richie- may as well have ordered direct from Sky in that case! Appreciate the response.
