Message 1 of 2
BT Sport on Youview issues
When watching the BT Sport channels through my youview box, there is continually interference on the picture where the top half of the screen pixelates. The sound at this time continues as normal. At other times the pictureis fine but no sound 😞
A broadband speed check says that everything is fine, but it is getting very annoying that you cannot watch something because of the issues. On the Ipad via WIFI, there are no issues ????????
Any suggestions? If it cant be solved BT can take the rubbish system out and I will go back to Freesat!!
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Sport on Youview issues
Hi ee12csvt,
Thanks for posting. Sorry you're having problems. How are you connecting the youview box? Is it via scart or hdmi? If it's scart can you try hdmi or vice versa? Let us know if that helps.
Cheers
David
