djcla
Message 1 of 10
BT Sport without sky subscription
Hi
I have recently cancelled my Sky subs and just going to pay for the £10 a month ability to record but wanted to still be able to view BT Sports.  Reading online and speaking to advisors leave s me wondering if it will actually work or not.  I have read that it should work if you have freesat from SKy but im ot sure if it will work if i have just got the record facuility enabled.   I wont find out until June when i get cut off.  Can anyone advise?
9 REPLIES 9
rarmitage124
Recognised Expert
Message 2 of 10
Re: BT Sport without sky subscription
You should be able to get BT Sport
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
rarmitage124
Recognised Expert
Message 3 of 10
Or if you can get Infinity you can have it on a Youview box
djcla
Message 4 of 10
No infinity, I long for the day I get decent broadband
chime
Message 5 of 10
I receive BT Sport and have FreesatfromSky. It's the only viewing I use the box for. Mine is only a receiver so don't know if you'll be able to record BT Sport.
chime
djcla
Message 6 of 10
Spewy
Message 7 of 10
The Sky channels have went off today and BT sports channel has message saying 'no signal being received' so unsure if this is the same dish related issue i was having with Sky or you cant actaully get BT without a subscription??
Hunter2660
Recognised Expert
Message 8 of 10
Sounds like your dish is the problem, (BT Sport is on a transponder which has a weak signal). Your best bet would be to book an engineer to check the alignment, LNB and cabling.
chime
Message 9 of 10
Over the last two days lots of channels have been transferred to a new satellite. Not sure if this is causing the problem but could well be.
See http://www.a516digital.com/2015/06/final-stages-of-satellite-transfer.html
chime
Message 10 of 10
Not any more, for UK viewers. They have been moved.
http://www.a516digital.com/2015/06/satellite-update-astra-2g-is-live-big.html#more
for details.
