Bilboo
Message 1 of 3
BT Sport
Why is ther an annoying side banner for soccer on the rugby broadcast. Please remove it, immediately.
2 REPLIES 2
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: BT Sport
If  you are referring to the L bar of information that BT Sport Europe  provide then after a mountain of complaints BT do now transmit a full frame version on the BT Sport Extra 6 channel which helps if you are watching live but as the programs are not listed in the BT Sport Extra 6 EPG guide doesn,t help if you are seeking to record the program. Live sport and first broadcasts of programs should be broadcast in full frame as I understand are programs overnight  c midnight to  approx  6 or 8am.
Mikey47
Message 3 of 3
Re: BT Sport
To view in full screen press the red button. You then get the math full screen BUT in SD!!!!!!!
