andrewcg
Message 1 of 3
BT Sport
I ordered BT Sport last week with a BT advisor.  Tried the App today and it tells me that my BT ID is not associated with BT support. Tried on-line and the checker tells me I don't have BT broadband.  Called BT helpline twice and both times I've been cut-off after holding for over 20minutes. Live Assistance says I'm 83 in the queue.  I've only been with BT for 6 weeks and have to call them about problems more than I did in 5 years with orange. Anyone have any ideas?
2 REPLIES 2
imjolly
Message 2 of 3
Re: BT Sport
have you tried to login to MYBT?  if you have not set up a MYBT account you should set one up by going to BT.com
IanDouglas
Message 3 of 3
Re: BT Sport
Your order may be progressing.
As the other respondent says go to MYBT and see what status you have, such as "order progressing". If this is the case then you apparently have to wait for BT to finalise your order before getting the service.
The stupid thing is if you were a BT BB customer before your new order, they do not recognise you as an existing customer because they are useless and can not correct a simple and known problem. At least you only wasted 20 minutes not 2 hours, like me.
