Message 1 of 3
BT Sports App login
My BT Sport subscription from Sky is not linked to my BT ID so I can't log into the BT Sport App. Help!
2 REPLIES 2
Message 2 of 3
Re: BT Sports App login
If you pay your BT Sport subscription to Sky then I'm afraid it doesn't entitle you to use the BT Sport app.  If you pay BT directly for BT Sport then you'll have an account number that you need to add to your BT ID using www.bt.com/mybt
Message 3 of 3
Cheers! I'll stop trying to find a solution now!! Thank you so much for your help!
