Message 1 of 4
BT Sports Ultimate via EE - no UHD/4K channel
Hi, I have BT Sports Ultimate via my EE phone, no Ultimate/HDR channels appear on the Xbox Series X or Android TV apps, can someone check my account is set up correctly please? When using the Compatibility Checker on the Xbox I get ticks against 4K Devices and Connection but against Account it says ‘Upgrade to BT Sport Ultimate to experience select events in glorious 4K HDR’ ?
Tags (4)
3 REPLIES 3
Message 2 of 4
Re: BT Sports Ultimate via EE - no UHD/4K channel
The device checker is showing exactly what BT sees as configured on your account - it has found the large screen add-on, but not the Ultimate one.
If you definitely have the Ultimate add-on then you'll need to call EE and ask them to re-send your entitlements to BT.
Message 3 of 4
 Last time I spoke to them it went backwards and forwards, gave up in the end. Will try again. This is the item I have on my account, Ultimate is in the description. When I try to add Large Screen it says I can’t, and the apps work in HD on the TV.
Message 4 of 4
Sorry - I know it's a pain. EE are having a lot of issues sending us the correct data at the moment. When you call them, their standard response should be to remove everything and send it through to us again.
